供稿: 厦门雄霸电子商务有限公司
发布时间:2015/12/3 9:22:46
MKS 1259B-00100SV
Burliegh Hi-Fase Fabry-Perot Etalon Interferometers Wavemeter Model HF-600-1
Whitley High Vacuum Pneumatic Ball Valve Nupro MDC
Varian Vacuum Research Chamber 6.5 ASA Elbow Flange MDC
Varian Manual Shut-Off Valve Gate Huntington MDC
Etalon HF-600-1
Varian High Vacuum Electric Feed Through 2.75" Flange Ceramic Current MDC A&N
Thermionics High Vacuum Research Chamber Shut-Off 2.75" Flange Varian MDC
MKS Baratron Pressure Transducer 50M Torr Cluster Vac
MDC Vacuum Research 13 � ”CFF Weld-On Conflat Varian Huntington
MDC High Vacuum Research 2.75" Flange Gas Chamber CFF Conflat Varian Huntington
Huntington Vacuum Research 13 �” CF Zero Length Reducer Varian MDC
Huntington High Vacuum Research Chamber Shut-Off CFF
Huntington High Vacuum Research 12”Flange Reducer Ring "NEW" MDC UHV Varian
Varian High Vacuum Research Chamber 2”ASA Gate Valve Cryo Trap
High Vacuum RGA Research Chamber 2 3/8"ID Residal Gas Analyzer Sid-Con Varian
Glas-Col Series O Hemispherical 100ml. Heat Mantel No. 396 Briskheat
Varian Cryo Stack 8 High Vacuum Cryogenic Pump CTI
Slo-Syn Synchronus/Stepping Motor Drive Compumotor
MDC High Vacuum Research Feed Through UHV 6"CFF Conflat Flange Varian
ITT Electronic Tube KU-247B Thyratron Excimer Spectra-Physics Quatin
AMAT Applied Material RF Source Semiconductor Wafering
Airco-Temescal Turbo Molecular Pump 514 Varian Edwards
Etalon HF-600-1
OFweek工控网讯:以中小型产品为主有目前在城网、农网改造上被推荐采用的新型配电变压器,它是第七代节能产品,还有卷铁心变压器、非晶合金变压器、全密封变压器、组合式变压器、干式变压器、高燃点油变压器、气体绝缘变压器等。这些变压器的生产工艺基本上能够借用上述大型变压器的生产工艺之外根据不同产品有不同的工艺特点。比如卷铁心变压器,目前生产的卷铁心变压器都是封闭式铁心有多级型和R型铁心,这就需要配备卷铁心机,特殊绕线机,铁心退火炉,不然很难生产出卷铁心变压器。
又如,为达到产品少维护而发展的波纹油箱型全密封变压器,就要配备波纹油箱生产线,目前我国有简易式波纹油箱生产线也能满足生产要求。非晶合金变压器,由于非晶带材特别薄为0.03mm并特别脆一般生产厂家很难加工成铁心,所以一般都是购买现成的铁心,如美国的联信公司的或中国钢研总院生产的。
随着国民经济的发展,城市向大型化,繁华化发展,人口密集,高层建筑成群。城网改造中规定110kV线路进城变电所以110kV变压器布站。
高燃点油种类很多如硅油Midel--7131油、α油、β油等,但综合各种因素还是β油最为合适。β油无毒与变压器用全部材料都相容,燃点308℃,价格适中每kg约20元RMB,只有粘度比变压器油稍大,因此在油道和散热上给予足够重视就可以。生产β油变压器基本不需特殊的专用设备。
进入首页浏览更多精彩内容:
创新没有止境 世界工厂掀起机器人投资热
中国机器人产业链公司面临重大机遇
OFweek工控网讯:照明系统是机器视觉系统最为关键的部分之一,机器视觉光源直接影响到图像的质量,进而影响到系统的性能。其重要性无论如何强调都是不过分的。好的打光设计能够使我们得到一幅好的图象,从而改善整个整个系统的分辨率,简化软件的运算,而不适合的照明,则会引起很多的问题。
机器视觉系统的核心是图像采集和处理。所有信息均来源于图像之中,图像本身的质量对整个视觉系统极为关键。而光源则是影响机器视觉系统图像水平的重要因素,因为它直接影响输入数据的质量和至少30%的应用效果。
通过适当的光源照明设计可以使图象中的目标信息与背景信息得到最佳分离,可以大大降低图象处理的算法难度,同时提高系统的精度和可靠性。反之,如果光源设计不当,会导致在图像处理算法设计和成像系统设计中事倍功半。截止目前尚没有一个通用的机器视觉照明设备,因此针对每个特定的案例,要设计合适的照明装置,以达到最佳效果。因此,光源及光学系统设计的成败是决定系统成败的首要因素。在机器视觉系统中,光源的作用至少有以下几种:
1)照亮目标,提高目标亮度;
2)形成最有利于图像处理的成像效果;
3)克服环境光干扰,保证图像的稳定性;
4)用作测量的工具或参照;
理想的光源应该是明亮,均匀,稳定的,视觉系统使用的光源主要有三种:高频荧光灯、光纤卤素灯、LED光源。目前LED光源最常用,主要有如下几个特点:
*可制成各种形状、尺寸及各种照射角度;
*可根据需要制成各种颜色,并可以随时调节亮度;
*通过散热装置,散热效果更好,光亮度更稳定;
*使用寿命长;
*反应快捷,可在10微秒或更短的时间内达到最大亮度;
*电源带有外触发,可以通过计算机控制,起动速度快,可以用作频闪灯;
*运行成本低、寿命长的LED,会在综合成本和性能方面体现出更大的优势;
*可根据客户的需要,进行特殊设计。
兴锐达不吹牛!想要比同行低15个点!请贵宾来电!保证满意!
Varian High Voltage Cold Cathode Vacuum Gauge Model 524-2 Pfeiffer
High Vacuum Research Chamber ISO NW100 Adaptor to KF50 Varian MDC HPS
GCA McPherson Monochromator Filter Attachment EU700 ISA
Gas Cell Hi Vac Research Absorption Chamber Varian MDC
EG&G Ortec 426 Linear Gate Module Canberra Tennelec Stanford Reseach
Vacuum Generators Civ Unit KF25 Varian Peiffer
UFI SCL BioLog Model 3992/1 Animal Data LCD Screen
Etalon HF-600-1
High Vacuum Research Chamber 13 1/4" CFF Conflat Blank Varian MDC
MDC High Vacuum Chamber 13.25" CFF Conflat Reducer Ring Huntington Varian
Edwards iQDP80/QDP80 High Vacuum ISO Flange 100-400N KF25 Varian
A&N High Vacuum Pneumatic Actuator Model 1539-S-N Whitley
MDC High Vacuum Research Chamber InLine Valve KF50 Shut-Off Varian
MDC High Vacuum Research Chamber 4.5" CFF Conflat Blank Varian Huntington
MDC High Vacuum Research Chamber 4.5" Del Seal BlankFlange Huntington Varian A&N
iQDP80/QDP80 High Vacuum ISO63/ISO100 Flang Edwards Varian
iQDP80/QDP80 High Vacuum Edwards ISO63/ISO100 Flang Varian Pheiffer
Huntington High Vacuum Research Chamber 8" CFF Conflat Blank Varian
Huntington High Vacuum Reasearch Chamber 8" Flange Conflat MDC Pfeiffer Varian
High Vacuum Chamber 200ASA Vacuum Fittings Varian MDC
Etalon HF-600-1
Pressure Transducer Vacuum Gauge 521A-5 " " Baratron 1K
Pressure Transducer Vacuum Gauge 503L " " Baratron 1K
联系人:刘锦燕
手机:13295922579
电话:0592-5580706
传真:0592-5361191
邮箱:LJY_05228@163.COM
QQ:2711934024
QQ:2574619415
如需了解更多信息,请访问 ( 厦门雄霸电子商务有限公司)官网 http://c.gongkong.com/xingruida/
厦门雄霸电子商务有限公司
地 址:福建省厦门市思明区吕岭路1733号2009单元(万科创想中心)
邮 编:361000
电 话:0592-5580706/13295922579
传 真:0592-5361191
网 址:http://c.gongkong.com/xingruida/
E-mail:LJY_05228@163.com
联系人:刘锦燕
